Creating a room finish legend
Command |
Path |
Create Rm Finish Legend |
Tools > Reports |
There can be dozens of room finishes assigned within a project file. To obtain a detailed report of all room finish data, first generate a room finish schedule as described in Using preformatted reports. Then generate a detailed legend showing a full description of the finishes using the Create Rm Finish Legend command. This command can only be used after room finishes have been assigned to space objects.
To generate a room finish legend:
Select the command.
The Create Room Finish Legend dialog box opens.
Select whether the legend should be organized by finish type, key, or surface location.
Select whether to place the legend on the drawing.
If room finishes are added or updated in the drawing later on, recalculate the worksheet to update the results. See Worksheet menu.
